LineCloser: Default setting Connect Z Mode
  • May 14, 2018 10:37 AM UTC
  • 86 views
nielsgerrits
Forum|alt.badge.img+67
After using the LineCloser to close 3D lines I discovered that some vertices in my dataset were changed. My assumption was that the LineCloser only adds a segment between the last vertice and the first vertice of the polyline but the Z from the last vertice was changed to the Z of the first vertice... Changing the parameter Connect Z Mode from "First Wins" to "Ignore" solved my problem. But I wondered if the setting "First Wins" was set as Default intentionally, and if so, why?
The image:
1. The open line.
2. The closed line with the setting First Wins. The Z value of the last vertice is changed to the Z of the first vertice.
3. The closed line with the setting Ignore. Now only a segment between the last and the first vertice was added, no vertices changed.
FME Desktop 2017.1.2 and 2018.0.0.2.
Workspace attached.
  • May 14, 2018 2:13 PM UTC
It seems that the parameter doesn't work at all, in FME 2018.0.0.3. In my observation, the LineCloser always ignores Z. @DanAtSafe, could you please check this?
fmelizard
Forum|alt.badge.img+22
  • May 14, 2018 8:13 PM UTC
Hi @takashi The z-value should only change if the x,y coordinates are the same for the first and last vertices. We'll fix this in FME 2019
fmelizard
  • May 17, 2018 5:36 PM UTC
@nielsgerrits This problem has been fixed in the latest FME 2019 betas. (not yet available) The Connect Z mode parameter now only applies to nodes with the same x,y coordinates so you shouldn't have to choose 'Ignore' to work around the problem.
