Limit decimal places of feature coordinates
vki
Forum|alt.badge.img+8
I use the swiss ili2fme-writer to write to an xml-like output-format. In the outputfile, the coordinates have 9 or 10 decimal places, but just 3 are allowed in the further processing.
Is there a way to limit the decimal places of the coordinates in FME (the ili2fme-writer obviously just writes what it gets...)
I found this issue:
https://knowledge.safe.com/questions/38634/coordinateconcatenator-attribute-string-limit-deci.html but it's about coordinates as an attribute.
or this:
https://knowledge.safe.com/idea/19776/add-parameters-to-control-decimal-places-to-geomet.html > is this idea already realized?
pratap
Forum|alt.badge.img+12
  • March 16, 2017
Can confirm that the CoordinateRounder just before the ili2fme writer will do the trick.
vki
  • March 20, 2017
oops, sorry, I should have seen this....
Thanks.
