json templater edit my null attribute value to ""(two double quotes)
  • February 10, 2022
  • 5 replies
  • 139 views
f.kemminje
Forum|alt.badge.img+11
In the source json file values.available_sf was null. i created a json templater
and
assign this null value to BuildingSqFtTotal jason object.
but after templater I got this "BuildingSqFtTotal" : ""
I need "BuildingSqFtTotal" : null
@david_r​ or anyone can you pls help
"BuildingSqFtTotal": fme:get-attribute("values.available_sf"),
Best answer by ebygomm
I think you need to make the attribute missing if you want to see null (no quotes) in the JSON output
  • February 10, 2022
Have you tried using a NullAttributeMapper to make sure that values.available_sf contains a <null> value and not an empty string?
f.kemminje
  • February 10, 2022
yes i tried, but not successful. any attribute if it is null, the template makes it as ""(double quote)
f.kemminje
  • February 10, 2022
@david_r​ David, here is my , template fme file
Forum|alt.badge.img+39
  • February 10, 2022
f.kemminje
  • February 10, 2022
yes, this is worked :) Thanks. But totally confused.
