Join tables based on contains, using inlinequery (Code works in Toad, Not in FME)
So I have a multi table joiner that I have been succesful with inside of Toad but I cannot get to excute inside of a SQLite transformer in FME.
I am essentially wanting to join the Region table to the Entry table if the column Entry.Category contains Region.Region_Name.
The code I am using is as follows:
select Entry.Category, REGION.REGION_NAME from Entry join REGION on Entry.Category like ('%' + REGION.REGION_NAME + '%')
Any help would be very appreciated!
Best answer by takashi
Although the SQL syntax is basically standardized, there also are partial differences depending on database engine. In the InlineQuerier, you have to follow SQLite specification, since the transformer uses SQLite database internally.
Try using || operator to concatenate string, instead of +.
from Entry inner join REGION on Entry.Category like ('%' || REGION.REGION_NAME || '%')
Takashi
  • May 28, 2015
Takashi
  • May 28, 2015
Takashi you are the man!!!
I totally forgot about that as a possibility!!
Works like a champ now.
-Garrett
