issue searching string
  • Jul 28, 2023 9:02 AM UTC
  • 9 replies
  • 187 views
rjr
I am trying to use the string search command to extract the file names from a text string, Path attribute. by reverse searching the path string in order to establish the location of the last sub directory i.e. \\
@FindString(@Value(Path),\\,-0,caseSensitive=TRUE)
The forward search works but I can't get the reverse (right to left) to work! using a negative startIdx
Best answer by nielsgerrits
Please also check the FileNamePartExtractor.
nielsgerrits
Forum|alt.badge.img+67
  • Jul 28, 2023 9:31 AM UTC
Forum|alt.badge.img+54
  • Jul 28, 2023 10:44 AM UTC
A negative start index doesn't mean it searches from right to left, rather that it returns the position of the first match from the end of the string rather than the start.
rjr
  • Jul 28, 2023 10:59 AM UTC
ok, but Isn't that effectively the same thing if im attempting to establish where the file name starts
  • Jul 28, 2023 11:18 AM UTC
Sorry, poor wording on my part.
Example:
Search the word pagan for letter a
imageIf start index is 0 or not set, this would return the a in position 1
If start index is set to -1 the search starts at position 4 and so the result is -1 (a is not found)
If start index is set to -2, the search starts at position 3, a is found and so the result is 3
If start index is set to -4, the search starts at position 1, a is found and sot he result is 1
The negative start index just sets the start of the search from the end of the string, the search itself is still left to right
rjr
  • Aug 1, 2023 9:57 AM UTC
Thanks for this, will try and find another way
  • Aug 1, 2023 12:33 PM UTC
What are you trying to get? The filename, the last subdirectory or something else?
The FilenamePartExtractor will give both the above
_filename - filename with extension
_rootname - filename without extension
_dirname - last subdirectory
rjr
  • Aug 1, 2023 4:54 PM UTC
The Path attribute was created from a dir listing exported to csv and not via FME, unfortunately. effectively just a string from which i'm attempting to extract the file name. if that makes sense?
  • Aug 1, 2023 5:04 PM UTC
The FilenamePartExtractor works on an attribute, so that's not an issue at all. Set the attribute containing your string as the Source Filenameimage
rjr
  • Aug 2, 2023 7:01 AM UTC
Thank you, that worked a treat
