Is there a way on FME to take out a sample from a table, where each field attribute is represented x amount of times in the sample?
  • Apr 14, 2024 10:12 AM UTC
  • 187 views
me.aelmo
I wish to extract a sample from a table where each attribute from some field should be represented x times. For example see below where x is 1, and the fields I want to sample from are House, Priority and Injury.
Input:
ID      Name    House       Priority    Injury
1        Draco   Slytherin    Medium  Head
2        Harry    Gryffindor  Low        Hand
3        Ron      Gryffindor  Low        Head
4        Cedric  Hufflepuff  High       Chest
Output:
j.botterill
Forum|alt.badge.img+69
  • Apr 15, 2024 12:28 AM UTC
hey there, perhaps the Sampler with a “group by: set to the fields you want x sampling rate
me.aelmo
  • Apr 15, 2024 1:59 PM UTC
This tends to generate an excessive number of samples, particularly when dealing with datasets containing numerous fields. Ideally, the number of samples should be set at n * 10, where n represents the distinct number of attributes of the field with the greatest number of distinct attributes.
evieatsafe
Forum|alt.badge.img+28
  • Apr 18, 2024 11:31 PM UTC
Hi @me.aelmo looks like you’re on the right track. If the issue is that your solution generates too many samples, then maybe sampling a second time could generate a smaller sample? You could perform this with either an additional Sampler, or maybe the solution would be to use a PythonCaller with a script that takes care of this scenario all in one transformer. I won’t be able to advise you on how to write this script, sorry to not be of more help. Let us know if you are able to solve this :)
