Is there a transformer in FME that can build sector polygons based on coordinates provided.
  • Apr 5, 2018 8:04 PM UTC
  • 64 views
shankar
e.g. Source data has 10,000 point geometries. Output needs to be list of polygons with no more than 500 points within the polygon.
daveatsafe
Forum|alt.badge.img+24
  • Apr 5, 2018 8:35 PM UTC
Hi @shankarvishwana,
Please try the following steps:
1. Use a PointCloudCombiner to create a pointcloud from the points.
2. Use the PointCloudDensityTiler transformer to break separate point clouds with a maximum number of points of 500. If this transformer is not available in Workbench, it can be downloaded from FME Hub.
3. Use a CenterPointReplacer to replace each point cloud with its center point.
4. Use the VoronoiDiagrammer on the center points to create the sector polygons.
shankar
  • Apr 10, 2018 1:23 PM UTC
Thank you very much. Followed your steps and the result was awesome!!
Thanks.
