Is there a better way to do basic math? I'm trying to parse file names from an SFTP call.
  • Mar 21, 2023 5:17 PM UTC
  • 88 views
fmejamesl
I'm parsing data from an SFTP call to get the file name. I'm returning _list values that have all the FTP properties of each file. I use an AttributeCreator get the length of this string as an attribute (ListStringLength=69) --- @StringLength(@Value(_list))
I'm also using the AttributeCreator to get the starting position of the file name based on the prefix as another attribute (StartingPosition=33) --- @FindString(@Value(_list),"00137 0001539147T")
  • 278361 Mar 21 09:49 00137 0001539147T ABCDEFG1234567.jpg
From here, I tried to simply subtract. But that didn't work.
@Value(ListStringLength)-@Value(StartingPosition) = a string value 69-33
So then I added an SQLExecuter and did the math in SQL and output the FileNameLength.
select @Value(ListStringLength)-@Value(StartingPosition) as FileNameLength
From here, I added an AttributeCreator to get the FileName. @Substring(@Value(_list),@Value(StartingPosition),@Value(FileNameLength))
I've uploaded my test fmw.
Thanks,
James
Best answer by hkingsbury
To perform arithmetic you need to wrap your statement (or part of a statement) in @Evaluate().
Take:
  • a=8
  • b=3
  • c=test
@Value(a)+@Value(b) = "8+3"
@Evaluate(@Value(a)+@Value(b)) = 11
@Value(c)-@Value(a) = "test-3"
@Evaluate(@Value(c)-@Value(a)) = <error>, can't subtract a number from a non number
@Value(c)+@Evaluate(@Value(a)*@Value(b))="test+24"
hkingsbury
Forum|alt.badge.img+73
  • Mar 21, 2023 6:53 PM UTC
Take:
  • a=8
  • b=3
  • c=test
fmejamesl
  • Mar 21, 2023 7:30 PM UTC
Take:
  • a=8
  • b=3
  • c=test
Ah! Brilliant! Thank you @hkingsbury​. I played around with @Evaluate but didn't have the syntax correct. This works great and eliminates the need for the SQLExecutor.
geomancer
Forum|alt.badge.img+71
  • Mar 23, 2023 7:36 AM UTC
If you don't want to do the math, you can leverage the power of regular expressions.
Both expressions below give the same results (I added an attribute with the file prefix).
@ReplaceRegEx(@Value(_list),^.*@Value(Prefix),@Value(Prefix))
@ReplaceRegEx(@Value(_list),.*?(@Value(Prefix)),\1)
Regex_Filename_Prefix
