Is FME working on a way for the Data Inspector to view a Hyper File and/or Reader for it?
  • Jan 17, 2023 3:47 PM UTC
  • 91 views
jbeaudoin
I found that after using the Hyper File Writer, that I had no way to open the file and view it in FME, and could only use Tableau to open the file to see the data there. I could not find a Reader for Hyper Files as well.
Best answer by jbeaudoin
Thank You. I have created the idea and anyone can go here and upvote it should you run across this same issue. AC Idea: Develop a Reader for Hyper Files (safe.com)
evieatsafe
Forum|alt.badge.img+28
  • Jan 23, 2023 5:27 PM UTC
Hi @jbeaudoin​ unfortunately it looks like FME can only Write to this format at this time, and therefore would not be able to Read in the data or preview it. There are plans for the release of a Reader for this format, but there is no timeline. I would suggest creating an Idea to gather more interest and influence the timeline of this being supported in the future :)
(looks like there is only an idea for the writer which is already supported)
jbeaudoin
  • Jan 23, 2023 6:30 PM UTC
