Intersection points
  • Mar 29, 2013 2:41 PM UTC
  • 7 replies
  • 755 views
Hello FME'rs,
What I'd like to do is intersect two line feature classes to produce an intersection POINT output feature class.
This is a relatively simple task to perform in the Arc geoprocessor (overlay->intersect).  However, my first few attempts with FME (using lineonline overlay) doesn't quite yield the results I want as it appears the give me the intersection points as well as ALL the start/end points of the intersecting line segments.
Can someone kindly point me in the right direction?
Thank you :)
JP
Best answer by fmelizard
Hi JP,
Create a list in the lineonlineoverlayer.
After overlaying, test the point features (geometry filter) to return only the points with a list that includes attributes of both features.
Hope this helps.
fmelizard
Forum|alt.badge.img+22
  • Mar 29, 2013 6:30 PM UTC
Hi JP,
Hope this helps.
  • Mar 30, 2013 10:30 AM UTC
Hi JP,
the easiest might be to just use the TopologyBuilder. It will output all the intersection points (nodes) without any further processing.
David
  • Mar 30, 2013 10:34 AM UTC
Sorry, apparently I missed the part about the start/end points. Use the CoordinateExtractor with the values 0 and -1 to get the start/end points and a 2DPointReplacer to convert them into points.
David
  • Apr 1, 2013 2:41 PM UTC
Hello Itay/David,
Thank you both for your quick and clear responses.  I believe I understood your answers well enough to make an attempt and currently in the process of doing so (the workbench is chugging away ...).  I don't know approach works best but once I'm done or stuck (and likely the latter) I'll let you know.  Thanks again.
regards,
JP
  • Feb 9, 2014 6:56 PM UTC
Hi all,
I cant bring the attributes from the point to a new shapefile. The values of the attributes List that store the ID of the lines that intersect at the point are not copied even doing Auto-connect attribute.
siriosus
Forum|alt.badge.img+4
  • Apr 27, 2023 11:09 AM UTC
Hi JP,
David
Hi David,
Could you please give a quick example?
Many thanks!
  • Apr 27, 2023 11:18 AM UTC
Hi David,
Many thanks!
Have a look at these tutorials:
https://community.safe.com/s/article/building-topology-calculate-route-length-topologyb
https://community.safe.com/s/article/Building-Topology (step 11)
If something is still unclear, consider posting it as a separate question for maximum visibility.
