Interpolate Z value on a 3D polyline
  • Nov 28, 2019 7:57 AM UTC
  • 163 views
roberto
Hello,
I'm here with a problem that I saw elaborated in other posts. I tried to apply some hints from there but unsuccessfully. The problem I'm facing is to assign Z values to geometries vertexes, taking them from other close ones, interpolating the values considering the distance (measure).
I tried with MeasureOrZvalueInterpolator but, sure because of wrong understanding of the transformer, without any results. Is this a problem to solve only coding?
Any idea, hints or already implemented examples?
TIA
bwn
Forum|alt.badge.img+26
  • Nov 28, 2019 11:17 AM UTC
Would it be accurate enough to create a Surface from the points that have the Z values you are trying to interpolate from and then Drape the features with the vertices across this? In Vertex Mode, SurfaceModellor will set the draped vertex Z values from the resulting triangulation, which is effectively a 3D interpolation operation I would guess?
roberto
  • Nov 28, 2019 11:35 AM UTC
Thanks. I'll give a try. But considering the polyline close to a linear object, I think the surface could be not consistent.
