Insert point at end of line
  • Mar 28, 2018 3:40 PM UTC
  • 6 replies
  • 684 views
owen
Hello,
I am trying to insert vertices at the end of lines, using the vertexcreator and 'insert point at index'.
To do this I am using -1 for the index, but this adding the vertex at the point one before last (see image).
How can I get the extra vertex to be at the end?
Thanks,
Owen
Best answer by redgeographics
Have you tried the Add Point option instead of the Index one?
Forum|alt.badge.img+63
dustin
Forum|alt.badge.img+36
  • Mar 28, 2018 4:28 PM UTC
Try the Snipper, with vertex option, start and end set to -1 and -1.
owen
  • Mar 28, 2018 7:17 PM UTC
Thanks, I hadnt thought of that. I was successfully adding points at the start index with 0 so thought -1 would work for the end as well
I see your logic, in fact I assumed that that would work as well... @NatalieAtSafe, could you check with the developers to see if this is expected behaviour?
  • Mar 29, 2018 8:02 AM UTC
In my understanding, the logic of the "Insert Point At Index" is "to insert a new point BEFORE a vertex specified by index". If you set 0, a new point will be inserted before the start node. As well, since -1 indicates the last vertex, I think the behavior is reasonable.
If you need to add a new point AFTER the last vertex, you need to use "Add Point" mode anyway.
fmelizard
Forum|alt.badge.img+22
  • Mar 29, 2018 6:48 PM UTC
@takashi and @redgeographics are correct. Specify 0 with "Insert Point at Index" to insert a vertex at the beginning of a feature or "Add Point" to add it to the end.
Currently if a negative value is set for "Insert Point at Index" which is >= the number of coordinates then the feature will be rejected with an fme_rejection_code of INVALID_PARAMETER_INDEX.
