increment a field for multiple file
I try to increment a field start at 1 and finish at the end of the file. I use a counter and it's work fin with 1 file. But i have 38 file. I need to start at 1 for each file. Do you have any suggestion? Thanks
Best answer by erik_jan
Use the Counter, but group by the file name (fme_basename).
That would start a new counter per file.
The grouping is done by using the attribute value in the Counter Name:
erik_jan
Forum|alt.badge.img+19
  • April 17, 2019
  • April 17, 2019
Thank you Erick. It's work.
