Identify string within text and remove all string after it
  • January 30, 2017
  • 5 replies
  • 499 views
This question is similar to the one posted here, however it is slightly different..
I am trying to replace string in a text_line_data attribute where the section of text i want to replace begins with a certain phrase and removes that + everything after it. So for example,
text_line _data:
"I like to use FME 2017"
I would like to identify all text which begin with "use", and delete everything (including that), after it. So, the result would be:
Remain: "I like to"
Removed: "use FME 2017".
The regular expression of ^ only applies to the start of the string, so would only recognize "I" as the beginning of the string.
Is there some way of setting the transformer to find a text string anywhere within an attribute and delete all string after it?
Forum|alt.badge.img+7
Hi @johnwk
I think you are looking for a so called 'positive lookahead' where everything before a specific regex is kept:
https://regex101.com/r/I6nlPY/1
.*(?=use)
You can use this regex in the StringSearcher.
erik_jan
Forum|alt.badge.img+18
  • January 30, 2017
Or you can use the StringSearcher (search for use) to find the location in the string.
Then use the SubStringExtractor (using the index from the StringSearcher) to retain only the part you need.
Forum|alt.badge.img+39
  • January 30, 2017
You could also use a regular expression in a string replacer to replace use and everything after it with nothing which make the regex a bit simpler
use.+
use.+
Great idea!!
Just a small idea, isn't it better to use 'use.*' (* instead of +) because 'use' might also be the last word
  • January 31, 2017
use.+
Much appreciated everyone! As I'm a regex novice, I tried a combination of @egomm and @jeroenstiers suggestion of 'use.*'. This worked perfectly! Thanks again.
