Identify similar lines between two networks
  • Dec 6, 2018 10:01 AM UTC
  • 439 views
djmcdermott
Forum|alt.badge.img+7
Hi FME'ers,
I have two network datasets, one for all streets and one for footpaths only. There are instances where the footpath and the streets follow a similar path. This is never exact and they often weave around each other, intersecting each other at multiple points. I need to find a way of identifying sections where the street network and footpaths are similar. The goals is to reconcile their geometries but the decison over which geometry take precedent is not mine to make.
I have attached an example. The green is the street network and the turquoise is the footpath.
Thanks,
David
Best answer by daveatsafe
Hi @djmcdermott,
The FME Hub transformer FuzzyParallelLineFinder should be able to find the matching sections of lines for you.
Forum|alt.badge.img+54
  • Dec 6, 2018 12:36 PM UTC
I would try buffering your road lines to create areas, then using these areas to clip the paths. Deaggregate the output and then keep only lines that are a significant length. What you should be left with are path segments that are running along/alongside the roads.
I wouldn't expect a perfect outcome from the above, looking at the sample data, but should be a start. Will probably require some trial and error with how much to buffer by.
daveatsafe
Forum|alt.badge.img+24
  • Dec 6, 2018 5:13 PM UTC
Hi @djmcdermott,
gio
Forum|alt.badge.img+15
  • Dec 6, 2018 5:27 PM UTC
@djmcdermott
Chop the lines of the datasets by 2. Extract ortientation.
Neighborfinder or Buffer at relevant tolerance.
Compare orientation. Keep those within some tolerance.
djmcdermott
  • Dec 13, 2018 1:44 PM UTC
Hi @djmcdermott,
This works pretty well. There are a few false positives and not all the lines get line_id's but it works.
