I would like to transpose the attached data structure. I have tried using the attribute transposer without luck. The attached excel has the input structure and the desired output. Many Thanks, Andrew
Best answer by geomancer
Create a list with ListBuilder (Group By: ID), and feed it to the custom transformer ListKeyValuePairExtractor from FME Hub. Finally expose the new attributes with the AttributeExposer. See the attached workspace (FME 2020.0)
fmetransposeNote: ListKeyValuePairExtractor uses Python under the hood.
geomancer
Forum|alt.badge.img+51
  • August 2, 2021
  • August 2, 2021
Thanks geomancer! It works like a charm.
