I want to grab numbers out of a string. Using the StringSearcher with reg expr "[0-9]+" does not give results, while using the reg expr " [0-9]+" (watch the leading space) does. What do I do wrong?
itay
Forum|alt.badge.img+19
  • May 12, 2017
Hoi Hans,
That depends on your input string....can you share an example?
itay
  • May 12, 2017
Hoi Hans,
Usually a \\d works just fine for numbers.
Groet,
Itay
This will give you the first occurring group (one ore more) of digits inside the attribute "string", returned in attribute "_first_match"
Example: "test123abc" as input will return "123".
