I need to remove text from an XML file, but haven't had any luck with XMLUpdater.
  • January 26, 2022
  • 7 replies
  • 411 views
This is what I'm trying to remove is this block:
    <Remarks>
 "<span><span>xxxxxxxxx </span><span class="xxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</span>
<span>xxxxxx </span><span class="xxxxxxxx">xxxxxxxxxxxxxxxx</span></span>" : 2022-01-24T08:23:34
 "<span><span>xxxxxxxxxxxxxxxxxxxxx (&lt;span class="xxxxxxxx"&gt;xxxxxxxxxxxxxxxxxxxxxxxx&lt;/span&gt;)</span>
<span>Suffix: T (&lt;span class="xxxxxxxx"&gt;xxxxxxxxxxxx&lt;/span&gt;)</span>
<span>xxxxxxxxxxxxxxxxx</span>
<br />
<span>---- </span><span class="xxxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</span>
<span>---- </span><span class="xxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxx</span>
<br /></span>" : 2022-01-24T08:23:39
 "<span><span>---- </span><span class="xxxxxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxx</span>
<span>---- </span><span class="xxxxxxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxxxxxxx</span>: <span class="xxxxxxxxxxxxxxxxx"> 3</span>
<span>---- </span><span class="xxxxxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</span>: <span class="xxxxxxxxxxxxxxxx"> 3</span>
<span>---- </span><span class="xxxxxxxxxxxx">xxxxxxxxxxxxxxxxxxxxx</span>
<span>---- </span><span>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.</span>
<span>---- </span><span>xxxxx</span>: <span class="xxxxxxx"> 2</span>
<span>---- </span><span class="xxxxxxxxx">xxxxxxxxxxxxxxxxx</span>
<br /></span>" : 2022-01-24T08:24:07
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    </Remarks>
I'm using the xml reader to pass the transformer, where I can only select the <span> when going to the text attribute selection. It removes only one span. The documentation isn't showing much. I'm not only new to FME, but also XML. Originally I was asked to upload xml files to a vendor through SFTP.
Thanks.
  • January 27, 2022
@davbistrath​ You could just use a regular expression:
<Remarks>.*?</Remarks>
in the StringReplacer. The ? make the .* match non-greedy so s it will remove multiple remark tags.
So the pattern in FME would be:
Textine reader - set the parameter Read Whole File At Once: Yes
StringReplacer - Mode: Replace Regular Expression
I've attached an example. (FME 2021.2)
  • January 27, 2022
Thank you very much, I will incorporate this.
  • January 28, 2022
Hi @davbistrath​ , I believe that XMLUpdater works as expected, if you need to remove all the <Remarks> elements from an XML document, like this.
Before
<Features><Feature>aaa</Feature><Remarks>bbb</Remarks><Feature>ccc</Feature><Remarks>ddd</Remarks>
</Features>
After
<Features><Feature>aaa</Feature><Feature>ccc</Feature>
</Features>
XMLUpdater parameters settings should be:
xmlupdater-parametrs
Just be aware that XMLUpdater always requires input from the Update port even if you don't need to use any attributes from the input feature. In this case, you can just send a feature created by the Creator.
xmlupdate-workflow-example
[Add] If you need to remove only the contents of <Remarks> elements, this setting is available.
xmlupdater-parametrs-delete-contents
  • January 28, 2022
Before
</Features>
After
</Features>
That's great, I see where I went wrong. Thanks!
mark2atsafe
Forum|alt.badge.img+48
  • January 31, 2022
Thanks for asking this great question. I made this our Question of the Week and posted a video about it on YouTube. Of course, Takashi has made a great answer already!
  • January 31, 2022
Before
</Features>
After
</Features>
So another question, I'm scanning a folder and wanting to modify all the files. I've setup a Folder and File Pathnames reader and have set my  XMLUpdater parameters as such:
XMLUpdater parametersIt's giving me an error that it can't find the files. Is this the correct way to handle this?
Thanks
  • January 31, 2022
Thanks
I suppose that the user parameter "SourceDataset_PATH" indicates a folder path, rather than XML file path. The PATH reader outputs features containing attribute called "path_unix" (or "path_windows") which stores a file path. Try setting the attribute to the XML File parameter.
