I need to convert csv to shapefile. How can I get the file name of the csv in the the attribute of the shapefile? I tried the fme_feature_type but its not working.
  • Sep 22, 2022 4:09 AM UTC
  • 5 replies
  • 93 views
tomfriedl
Forum|alt.badge.img+14
  • Sep 22, 2022 8:01 AM UTC
fme_dataset = filename with path
Forum|alt.badge.img+54
  • Sep 22, 2022 8:47 AM UTC
If you change this setting in the csv reader fme_feature_type will contain the filename.
@malavikavenu96​ exposing fme_basename should give you what you need
@Mark Stoakes​ @ebygomm​ @tomfriedl​ I have tried all these methods still the output is not received. Before I had used the same for shapefiles but it is not executed for csv files. I tried using the FeatureReader but it is taking a lot of time.
@malavikavenu96​ If you attach a couple of sample files and your existing workspace then someone might be able to dig a little deeper
