I need to convert a csv file into a shapefile in a .Net 6 windows application. I am looking for some assemblies or source code that does to use in the application. Does FSE provide such assemblies or have source code that can use the does this?
  • December 8, 2022
  • 17 views
  • December 8, 2022
If you have a licensed installation of FME, you can use the included .NET API for this.
You'll find the documentation under <FME>\\fmeobjects\\dotnet\\apidoc
There's also a sample application under <FME>\\fmeobjects\\samples\\CSharp
If, for some reason, you cannot find the files, make sure that the SDK was selected during installation of FME.
