I'm working with a geometry in wkt. I would like to convert to lat, long and elev using FME. I can do conversion using SQL using "select ST_AsText(geom)". I've tried the geometry extractor translator and it just gives errors. There is an example be
  • Jan 13, 2023 4:23 AM UTC
  • 5 replies
  • 571 views
mtm102582
Line:
01020000A0E610000005000000E040A17B843554C0C987F51E7593414000000000000000006CDB4900853554C0AFD3A0F17893414000000000000000002D2683FB813554C0D677B1BD8E93414000000000000000005A484B8E7F3554C025457646AB9341400000000000000000C4B449797B3554C01A0A32C8AC9341400000000000000000
Using SQL the wkt converts to these 5 points:
 -80.83621111628918 35.15201174725332 0,
-80.83624274456605 35.15212841370464 0,
-80.83605850036174 35.1527936092895 0,
-80.83591039039439 35.15366440558345 0,
-80.83566124151099 35.15371038859685 0
Lat and long are also reversed in the output. I would like to do this conversion in FME for spatial analysis of the full data base.
Thank you,
Matt
Best answer by geomancer
Your input data turns out to be in HEX Encoded OGC Well Known Binary format.
HEX-Encoded_WKB
Forum|alt.badge.img+63
mtm102582
  • Jan 13, 2023 6:43 AM UTC
But how do you read wkt in fme and write to lat, long, elev. ​ I have not been successful with this. I can only get it to work in sql.
  • Jan 13, 2023 7:41 AM UTC
My preference would be to cast the geometry column to WKB (if possible, it's more efficient than WKT) in SQL and then use the GeometryReplacer set to WKB in your FME workspace to rebuild the actual geometry. Finally, use e.g. the CoordinateExtractor to get the numerical values for each vertex.
geomancer
Forum|alt.badge.img+71
  • Jan 13, 2023 10:36 AM UTC
HEX-Encoded_WKB
mtm102582
  • Jan 13, 2023 3:08 PM UTC
HEX-Encoded_WKB
Thank you! I'm back in business!
