I'm trying to use ImageFetcher, was wondering how the input data would have to look like. The URL to call is clear to me but with which data would you feed the ImageFetcher? I tried points, polygons and polylines and none of them worked.
  • Nov 16, 2023 1:06 PM UTC
  • 11 replies
  • 203 views
Are there any specific coordinate strings or bounding boxes to be created for the ImageFetcher to understand where to fetch from a URL? I.e. I tried to fetch from a XYZ tile server and it works flawless in QGIS. The same URL doesn't work with the ImageFetcher for some reason.
itsmatt
Forum|alt.badge.img+48
  • Nov 16, 2023 1:51 PM UTC
The image fetcher only works for images - essentially the ImageFetcher is an HTTPCaller with a building in FeatureReader pointing to the downloaded image.
For example if i point the URL to the random image I found via google images:
https://www.thedesignwork.com/wp-content/uploads/2011/10/Random-Pictures-of-Conceptual-and-Creative-Ideas-02.jpg
imageFME will download the image and read it in with the JPEGReader - you can see evidence of the JPEG reader in the log fie  e.g.,
JPEG reader: Directive '_DELETE_SOURCE_ON_CLOSE' has the value 'yes'
There is also the Content-Type which you can either set to Auto or you can specify it manually.
If the headers are not set correctly then you will need to specify it manually.
the image fetcher will not with with vector features like point, lines, etc
What is the URL you are trying to read from?
  • Nov 16, 2023 1:58 PM UTC
Pluss one for the reply from @virtualcitymatt​ .
Could you perhaps try with the "OGC WMTS (Web Map Tile Service)" format in a FeatureReader? It will let you pass polygon as bounding boxes and format the request URL accordingly.
  • Nov 16, 2023 2:39 PM UTC
Here's the URL https://tile.opentopomap.org/{z}/{x}/{y}.png and attached is a sample area for which I would want to load tile through ImageFetcher.
nielsgerrits
Forum|alt.badge.img+67
You can, but it is not out of the box.
For example, you can use https://a.tile.openstreetmap.org/5/9/12.png in the dataset, but you will need to calculate x and y from the coordinates. And the returned pdf's are not georeferenced, so you will need to do that as well, using a RasterGeoreferencer.
  • Nov 16, 2023 2:52 PM UTC
this is the setup in FME 2023.0 image
  • Nov 16, 2023 2:58 PM UTC
hm, I thought to be able to download tiles (.png) from the given area of interest. So that doesn't work? Is ImageFetcher the wrong Transformer?
  • Nov 16, 2023 2:59 PM UTC
I need to download from an XYZ tile server..
nielsgerrits
No, Safe did not implement XYZ tiles, as far as I know. They did implement WMTS and, as @david_r​ pointed out, you can use this as expected with a FeatureReader.
As said, I think you can build this yourself, but it will take some effort.
  • Nov 16, 2023 4:57 PM UTC
Indeed, it shouldn't be too complicated. This article shows how to calculate the tile numbers based on a bounding box, with concrete examples in Python:
https://medium.com/@ty2/how-to-calculate-number-of-tiles-in-a-bounding-box-for-openstreetmaps-4bf8c3b767ac
  • Nov 17, 2023 8:39 AM UTC
got it, thank you for looking into it!
  • Nov 17, 2023 9:30 AM UTC
Here's some sample code for the PythonCaller that will accept a bounding box geometry (should be according to EPSG:4326) and will output one feature for each tile that is covered. You have to provide the zoom level as an attribute "z" to the PythonCaller. The output from the PythonCaller will contain the new attributes "x" and "y" (you'll have to expose them in the PythonCaller settings) which, together with the input "z", you can use to build the URL that is then passed to the ImageFetcher.
import fmeobjects
from itertools import chain
from math import log, tan, radians, cos, pi, floor
# Based on https://jimmyutterstrom.com/blog/2019/06/05/map-tiles-to-geotiff/
def sec(x):
    return(1/cos(x))
def latlon_to_xyz(lat, lon, z):
    tile_count = pow(2, z)
    x = (lon + 180) / 360
    y = (1 - log(tan(radians(lat)) + sec(radians(lat))) / pi) / 2
    return(tile_count*x, tile_count*y)
def bbox_to_xyz(lon_min, lon_max, lat_min, lat_max, z):
    x_min, y_max = latlon_to_xyz(lat_min, lon_min, z)
    x_max, y_min = latlon_to_xyz(lat_max, lon_max, z)
    return(floor(x_min), floor(x_max),
           floor(y_min), floor(y_max))
class GetXYZTilesByBbox(object):
    def __init__(self):
        pass
    def input(self, feature):
        fme_bbox = feature.getGeometry().boundingBox()
        zoom_level = int(feature.getAttribute('z'))
        bbox = tuple(chain.from_iterable(fme_bbox))
        tile_list = bbox_to_xyz(*bbox, zoom_level)
        for x in range(tile_list[0], tile_list[1]+1):
            for y in range(tile_list[2], tile_list[3]+1):
                tile_feature = feature.cloneAttributes()
                tile_feature.setAttribute('x', x)
                tile_feature.setAttribute('y', y)
                self.pyoutput(tile_feature)
    def close(self):
        pass
The georeferencing is left as an exercise for the reader, but there's sample code to be found in this excellent article that I used as basis for the above: https://jimmyutterstrom.com/blog/2019/06/05/map-tiles-to-geotiff/
