I built Excel file attribute feature joiner workflow and I am happy for that.
  • Dec 12, 2024 2:19 PM UTC
  • 87 views
evoteck
Forum|alt.badge.img+31
Hi folks, I had some urgent need at my workplace, as the GIS database administrator working in a electricity distribution company, I was required to draft out various district data to be used by another department which will require me to decode and clean the data to enable them understand the data format based on their needs. I tried using manual method of copy and past after extracting this data from the database but it was time consuming.
I tried FME and I was able to create a workflow using two transformers FeatureJoiner and Matcher and I am happy how this workflow was able to query the two excel files added to the left and right part of the FeatureJoiner transformer thereby giving me the output based on joined attributes file, one is coming as a number and varchar.  Feel free to connect with me on linkedin https://www.linkedin.com/in/anthony-ezema/
Best answer by kailinatsafe
Hello ​@evoteck, an awesome solution! Thank you for sharing your success! Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Dec 16, 2024 4:54 PM UTC
