I am trying to generate measure along a line, including curves, read from DXF and eventually want to write this line, including measure to a GML.
  • Nov 20, 2023 1:51 PM UTC
  • 82 views
I read the line from a DXF reader, generate measure using the measuregenerator and then write it to a GML. The line including the curve end up perfectly in the GML, but I do not see any measure.
Any suggestions?
daveatsafe
Forum|alt.badge.img+24
  • Nov 27, 2023 8:18 PM UTC
GML doesn't support measures on the geometry, but you could use a MeasureExtractor and ListConcatenator to extract the measures into a comma delimited list that can be added to the GML output feature:
Screen Shot 2023-11-27 at 12.17.31 PM
