I am trying to extract records from one table based on a series of date ranges in another table. I want all the records from table A, that fall between date ranges from table B. Each table B row has a start date and end date.
  • Mar 17, 2022 6:16 PM UTC
  • 106 views
zanzibarjack
@zanzibarjack​ If the data is in a database then you can use SQLExecutor to run a SQL BETWEEN query on the two tables. If the data is form Excel or CSV then you can do the same query, but using InlineQuerier
zanzibarjack
  • Mar 17, 2022 6:38 PM UTC
Thank you or your response. I hoping to automate the process instead of manually typing in each date range. The date ranges are coming in from a separate table than the records I'm trying to filter.
hkingsbury
Forum|alt.badge.img+73
  • Mar 17, 2022 7:46 PM UTC
You'd make one call to table containing the dates, then use those vlaues in an AttrbiuteCreator to create the WHERE clause and pass that into an SQLExecutor or FeatureReader
@zanzibarjack​ There's an InlineQuerier SQL example by @Takashi Iijima​ here
