HTTPCaller POST: error "415"
  • Jul 2, 2021 2:08 AM UTC
  • 156 views
Hello,
I am trying to POST an XML using the HTTP Caller, but get a 415 error.
I have an API tool for the application that I am trying interact with, and manage to POST the XML with success.
I have seen other posts that suggest it is the header of the XML / Content Type option which is incorrect, but I have tried all the options I can think of.
Any help would be appreciated.
I have pasted the XML I am using below, and attached the test  workbench I'm using.
Note that I have deleted credentials / sensitive information.
Cheers
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<Mail>
<TotalAttachmentCount>0</TotalAttachmentCount>
<Confidential>false</Confidential>
<RichMailText>false</RichMailText>
<MailSubject>TEST2</MailSubject>
<ToUserId>1476934057</ToUserId>
<MailTypeId>2154</MailTypeId>
<MailFormFields>
<MailFormField identifier="DesignPackage_singleSelect">N/A - Not Applicable</MailFormField>
<MailFormField identifier="Discipline_singleSelect">PM - Project Management</MailFormField>
<MailFormField identifier="Contractprogram_singleSelect">***SOMETHING HERE***</MailFormField>
<MailFormField identifier="Location_singleSelect">ALL - Project Wide</MailFormField>
</MailFormFields>
</Mail>
Best answer by caracadrian
You should look into the API docs Mail | Support Central (aconex.com)
Aconex requires you to supply both a Header and a POST payload and setting the Content Type manualy.
caracadrian
Forum|alt.badge.img+23
  • Jul 2, 2021 4:52 AM UTC
Thank you.
I did not know that it was possible to set the content type manually. For those interested, in the future, below is my HTTP Caller parameters and payload.
--myboundary
Content-Type: application/vnd.aconex.mail.v3+xml
<Mail>
<MailFormFields>
<MailFormField identifier="Discipline_singleSelect">GN - General</MailFormField>
<MailFormField identifier="Contractprogram_singleSelect">***</MailFormField>
</MailFormFields>
</Mail>
--myboundary
Capture
