HTTPCaller Enverus API v3 custom header parameter ignored in Form but works in Postman
rzickuhr
Participant
Enverus’s Developer API has a custom header option to change the location of next link from the header to the body. When I put X-Omit-Header-Next-Links in the header of Postman I get the expected response:
Results from Postman
putting X-Omit-Header-Next-Links in the header of HTTPCaller seems to be ignored as no next link is in the response body and the link remains in the response headers.
HTTP Caller with X-Omit-Header-Next-Links
Bottom of response body in Form
Returned API header attributes in Form
Am I doing something wrong or has anyone experienced this behavior?
Thanks in advance,
Randy
hkingsbury
Forum|alt.badge.img+55
  • May 21, 2024
Do you need to pass a value through for the header? FME might be dropping it as it doesn’t have a value. Try with a <space>?
rzickuhr
Participant
  • Participant
  • May 21, 2024
Thanks, good thought, I suspected the same thing and tried a space, single and double quotes none of which worked. There doesn’t seem to be a way to inspect what is being sent by HTTPCaller from within Form. Perhaps I need to use something like Wireshark to inspect what is being sent?
hkingsbury
  • May 22, 2024
I’ll often use Fiddler to verify outgoing calls from Form. Wireshark should also work.
Its definently a valid approach, then you can compare the succesfull call from postman and the one from Flow.
I have noticed in the past that the library that FME uses to send requests adds some of its own headers. In the ‘worst’ case this caused the API i was calling to reject my requests as on of the headers identified it as coming from a python library and the API blocked it as it treated it as a web scraper!
