HTMLReportGenerator Output with 'None' in Records
Hello...any idea how to remove the word 'None' from blank records present within a html report created with HTMLReportGenerator? Thank you.
Best answer by jdh
There's isn't an option on the HTMLReportGenerator for handling missing attributes, but you can get around this by adding empty attributes to the features missing them.
jdh
Forum|alt.badge.img+41
  • June 2, 2016
  • June 3, 2016
Thanks @jdh. I added a couple of empty fields using AttributeCreator then referenced these in HTMLReportGenerator and no more 'None' in the resulting output report.
