HTMLreportgenerator ESRI leaflet - feature layer URL more info needed
  • September 2, 2021
  • 6 replies
  • 149 views
j.botterill
Forum|alt.badge.img+40
Hi there,
I'd like to add an arcgis online feature service to my Html report. When I use the Map Esri leaflet, I'm confused by the terminology of 'feature layer URL'....
Documentation/help
This parameter allows the user to specify a list of comma delimited ArcGIS Online feature layer URLs, that will be displayed as additional layers on the map.
Is this the feature service item Id URL? or do we need to be more specific and enter the REST URL of the layer in the feature service?
htmlReport_Map_esriLeafletAs I understand it leaflet provides visualization capabilities for data hosted in Feature Services, Map Services & Image services.
I think the documentation needs some detailed wording and/or examples. I don't seem to have much luck using this option in the html reports, but I'd very much like to!
nielsgerrits
Forum|alt.badge.img+54
You need the rest url of the layer in the feature service, for example:
https://services6.arcgis.com/C4zx6qagYX0uyqZP/ArcGIS/rest/services/ServiceName/FeatureServer/0
  • March 30, 2022
I have the same issue, doesn't work for me either with the REST URL.. DID YOU SUCCEED? thanks
j.botterill
  • March 30, 2022
Yes if the REST web service is a feature service... but some other services like raster tile image service layers do not
  • June 11, 2022
can we add Othophotos or feature classes from File GDB (ArcGis Pro) ?
j.botterill
  • June 13, 2022
You would first need to publish them to ArcGIS Server / portal or ArcGIS online. Go to the item description and find out the REST URL (bottom right hand corner). Paste this link into the htmlreportgenerator Leaflet feature layer URL
tdun
Forum|alt.badge.img+3
  • November 6, 2023
raster tile image service layers would be quite useful if supported
