How to use python caller and use neighborhood finder in python caller
  • Jun 19, 2023 3:27 PM UTC
  • 85 views
I have 100 neighborhood finder, in each neighborhood finder the two input are matched and umatched from the first transformation and the two output are used as inputs in the next transformation, i want to used python caller for solve this problem
  • Jun 19, 2023 4:00 PM UTC
You can't really use the NeighborFinder transformer inside the PythonCaller, but it shouldn't be very difficult to roll your own Python code that does something similar, and loop over it accordingly. E.g.
https://medium.com/analytics-vidhya/finding-nearest-pair-of-latitude-and-longitude-match-using-python-ce50d62af546
cannot create a pyhton script and use this transformation ?
  • Jun 20, 2023 6:36 AM UTC
The fmeobjects interface only offers a very limited subset of the regular transformers, unfortunately.
https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.html
But it's not very difficult to replicate the functionality of the NeighborFinder in Python.
