How to use Multiple Choice parameter.
  • Sep 2, 2020 11:29 AM UTC
  • 318 views
fme_hans
I created a Choice Multiple parameter and when i start the workspace i can check some values. But how can i test on the checked values? I tried a tester but that doesn't seem to work.
Best answer by ebygomm
It's much more difficult than it should be, especially if any of your choices contain spaces!
You could use the MultiChoiceParamSplitter custom transformer to put all your choices in a list and then use a ListSearcher to test for if a value matches one of the list items.
You can turn the parameter into a comma separated list, and then use this as the value with the IN operator in the tester. If you have no spaces in your options this is fairly straightforward to do.
Forum|alt.badge.img+54
  • Sep 2, 2020 11:48 AM UTC
fme_hans
  • Sep 2, 2020 12:21 PM UTC
Thanks, that works.
