How to use an attribute in the Regular Expression field of StringSearcher?
toedeledokie
Hi there!
The attribute is composed of concatenated values.
When I test if the concatenated values work as a regex, it succeeds:
02But when I try and use the created attribute, it doesn't match.
01I would love your input, please.
Best answer by danilo_fme
Hi @toedeledokie​
Attached the Workspace.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • June 5, 2021
Hi @toedeledokie​
You need to use the transformer to merger your informations, like the transformer FeatureMerger ou FeatureJoiner before the StringSearcher.
Thanks in Advance,
Danilo
toedeledokie
danilo_fme wrote:
Hi @toedeledokie​
Thanks in Advance,
Danilo
Appreciated. Will give it a go. Fought a bit with it all earlier today 🙂
toedeledokie
Sorry @danilo_fme​ ,
I've had no success with FeatureMerger. Both columns have to have the same values, no? Name in file_a and Name in file_b differ but have substrings in common.
I pored over the FeatureMerger documentation as best I could.
File_a:
file_a_nameFile_b:
file_b_name Workspace:
workspaceHere's my workspace attached, with some of the files. There are more files I need to do this kind of merger with but it's gotta succeed first with file_a and file_b.
danilo_fme
  • June 8, 2021
Hi @toedeledokie​
Thanks in Advance,
Danilo
toedeledokie
danilo_fme wrote:
Hi @toedeledokie​
Thanks in Advance,
Danilo
Amazing, thank you! I could not, for the life of me, figure out how to pass along the regex and you whipped this up making it look so easy.
A million thanks for the lesson 🙏
