How to upload shape to geoserver rest api?
  • Oct 28, 2022 5:54 AM UTC
  • 453 views
limo
Forum|alt.badge.img+8
I will try to upload shapefile to geoserver over the rest api.
This should be possible with the HTTPCaller! I am using the following option: - http methode: PUT
Upload from data
imageBut I get the error:
I have access to the given url. So what is the problem here?
Does someone has experience in uploading shapes to geoserver with fme?
Best answer by limo
thanks for your hint!
I found out that the url was not correct. I need to add .../file.shp that Geoserver (rest) knows nex external data will come. Furthermore I need all files of the shape. So I have to zip all files and to define "application/zip" as content-type.
Now it work. New data will be published on the server and the layer is created automatically in geoserver.
nielsgerrits
Forum|alt.badge.img+67
I have no experience using GeoServer's API. As this is a specific GeoServer, not FME question, I think you probably have more reponse if you ask this on https://gis.stackexchange.com/
That being said, my best practice to learn how to work with the syntax of a new API is to use PostMan. When it works, replicate the webrequest(s) in HTTPCallers in FME.
limo
  • Oct 28, 2022 10:45 AM UTC
