How to Trim the overlap lines based on priority
  • Jan 30, 2020 5:32 AM UTC
  • 9 replies
  • 90 views
Requires functionality in a CAD environment that allows anyone in the * .dwg or *.shp file layers to prioritize what can be common "Trim" the lines (TRIM function) according to the given priorities.
nielsgerrits
Forum|alt.badge.img+67
If I understand correctly you want to generate this:
This can be done with a LineOnLineOverlayer and a LineCombiner, see attached workspace.
PriorityTrim(2019_1_2).fmwt
PriorityTrim(2016_1_1).fmwt
  • Jan 30, 2020 7:11 AM UTC
Thank you so much for your reply. I am using 2108 version FME, so it was not working .Can i get the *.fmw format ?
Please help
nielsgerrits
Please help
I saved the workspace as 2016 and added it to the original answer.
  • Jan 30, 2020 9:18 AM UTC
Please help
Thank you so much
  • Jan 31, 2020 7:38 AM UTC
Hi ,
i was worked with one sample file with 12 layers & 12 Priority.It was not working properly .In some places layers had changed in to other layers & Lines are also not Joint according to the layers.
Please help with my sample file..
priority.txtSample_Topo.dgn
  • Feb 2, 2020 4:36 AM UTC
Hopefully this works as expected.
igds2none.fmwt (FME 2017.1.2.1)
The boundary lines of input areas can be transformed into a network edges, and the priority of each edge is determined by one of two (left and right) layers. So, duplicate each edge into two for left area and right area, merge layer name and priority from area to the edges, keep one having higher priority, then connect them grouping by original Layer name.
  • Feb 3, 2020 10:31 AM UTC
Thank you so much for your answer.all the steps was working fine,
I was hanged in Converting to the original level name.
Please help
  • Feb 3, 2020 3:17 PM UTC
I thought that the layer names in your dataset represent priorities. How would you like to determine the priorities based on the layter names?
koenterralytics
Forum|alt.badge.img+12
Somehow I'm not able to download the workspace. Might be something with the design of the new community pages? Is it possible to share the prioritytrim workspace again? Thanks!
