How to transfer the attributes? Why some attributes were not tranferred?
  • Aug 16, 2022 12:38 PM UTC
  • 156 views
I've an ArcGIS geodatabase feature class with some attributes. I do some attribute mapping and export data in a new geodatabase feature class.
Everything works fine but some of the original attributes are not transferred in the output data. I don't know why......
I've used the Attribute Manager to remove and rename some attributes, then I've used the Attribute Creator and the Attribute Keeper, the last step is with a final Schema Mapper and finally the new feature class: but there are some attributes (not interested by any transformation during the process) that are missing (the fields in yellow).
Any idea? Thank you
mapping
Forum|alt.badge.img+63
You can manually edit the output feature type's schema to add those attributes, or set the attribute definition to "Automatic", but that will make a very broad guess as to the attribute types and sizes, so if you do that I'd recommend you set it back to manual and edit where necessary.
Hard to say where the attributes go missing in your process without seeing your complete workspace.
