how to test a boolean?
in former versions of fme Desktop i used the tester for testing a boolean Attribute. now i found, that in v 2018 the transformer "tester" doesn't allow a test on true/false any longer.
what can i use instead?
thanks in advance for your assistance!
Frauke
Forum|alt.badge.img+38
  • October 19, 2018
The attribute validator will allow you to test this
  • October 19, 2018
Thanks, egomm, but that will not solve my Problem.
I need to test the attribute if it is false or true. i only need those with the value "false".
thanks,
Frauke
  • October 19, 2018
thanks,
Frauke
Is there a reason you cannot use attribute = false in the tester?
  • October 19, 2018
You can most probably test it like it was a string, e.g. test for "true" or "false"
fmelizard
Forum|alt.badge.img+18
  • October 22, 2018
We did not intend to change anything here. If you can send screenshots of what has changed to https://www.safe.com/support/report-a-problem/ we'd be pleased to give a look.
