How to style the last line of Multitext differently than the rest of label.
  • Dec 16, 2019 9:50 PM UTC
  • 50 views
I have some labels in an ESRI annotation feature class and I am trying to style the last line of the text differently than the rest of the text string, I tried using attributeSplitter, splitting the text at the new line symbol and then using the test filter to find the line of text I want to style differently. After that I am aggregating the text back together that I don't want to style differently. Then I used DWG styler to style the 2 text strings differently. The only problem is that they are not aligned after I split and then aggregate the text.
I want to make the label like this
The text string comes into FME from ESRI file gdb like this
Has anyone done something like this before? I have attached example workspace of what I tried to do
  • Dec 17, 2019 12:25 PM UTC
I found a method that works I used the bounding box of the annotation to create 2d grid w centerpoints, then I use methods, attribute splitter, list exploder, feature merger and dwg styler here is workspace in case someone else would like it.
textexampleworks.fmwt
