How to split strings then concatenate them ?
gogopotter90
Forum|alt.badge.img+13
Hello ,
I have four tables. Each table includes an attribute called result, which contains fields value  string string number. (Hello Community 30 ) ,all tables share a common attribute id
I would like to combine the output from all four tables into a single attribute called result
String                String                    String             String
String number  String number   String number.  String no.
I would like the first string from each table to always appear above and the second string  and number written on the next line and All values should be combined into the same field.
Thanks on advance
Best answer by takashi
Thank you for confirmation.
I think the workflow shown in the screenshot could help you. See also the attached workspace example to learn more.
Hope this helps.
  • April 25, 2025
Hi ​@gogopotter90 ,
Assuming that these 4 records will be read from 4 tables - one record per table.
table id result
table 1 1 AAA BBB 100
table 2 1 CCC DDD 200
table 3 1 EEE FFF 300
table 4 1 GGG HHH 400
In the case above, do you want to write these two records into a single destination table?
line id result
1 1 AAA CCC EEE GGG
2 1 BBB 100 DDD 200 FFF 300 HHH 400
gogopotter90
  • April 25, 2025
@takashi thanks for reply
I need to write the output into result column ,as you wrote
when each table have same id
first line AAA CCC EEE GGG
Second line BBB 100 DDD 200 FFF 300 HHH 400
  • April 25, 2025
Hope this helps.
