How to split a shape file by count
abinash
I want to split my shape file to 6 parts. The count is aprox 600000. How to do this using if condition. Pls guide me
Forum|alt.badge.img+50
Do the parts have to be geographically contiguous?
abinash
  • December 8, 2021
no i just wanted to divide this huge shape file to smaller parts. And just now i found how to do it by writing conditions. Thanks for your response.
hkingsbury
Forum|alt.badge.img+55
  • December 8, 2021
I'd suggest that to split a large spatial data set, you tile it. As @Hans van der Maarel​ alluded to, you may not need it to be geographicalyl contiguous, but there are massive benefits of having the data in a constrained spatial extent
  • December 10, 2021
@Abinash Rout​ You can use the ModuloCounter - set the Count Maximum to six. Then out the output feature type, for the Shapefile Name, use the Text editor to add the count as a suffix:
myshapefile-@Value(_modulo_count)
