I have a problem. First my FME:
It is partly in Dutch, but it doesn't matter here. It is about spatial data with some features. There are two feature readers: the first one to select features which fall within a pre-defined contour, the second to select features. The attribute manager to add some attributes. The featurewriter to write the data in gdb format.
In the FeatureReader you can see attributes for “pand_v” and for “scheiding_v”. The attributes of “scheiding_v” are standard, hence the same for other features, except for “pand_v”. The difference is that in “pand_v” BGTPlusType is replaced by “identificatieBAGPND”. The features are of several geometric types: lines, polygons and points.
In the output of FeatureWriter all the attributes as given in the AttributeManager are shown. I'd like to see that for “pand_v” no BGTPlusType is given (there is no value here) and that for all other features no “identificatieBAGPND” is shown. And that some other attributes like fme_…, attribute{}…, etc., are not shown.
To be complete, here is the FeatureWriter:
How can I achieve that?
