How to replace parenthesis in my data
How do I automatically delete both the parenthesis and the content in them from my reader file? Is String Replacer the transformer to use? If so, can you help me with the code needed to find and replace any () and the numbers inside them with a blank. in other words, I want to delete them. This will probably be easy to a lot of you so I really appreciate your help.
  • May 15, 2016
Hi @dshaw, yes the StringReplacer should do that. Try this setting.
  • Text to Match: \\(\\d+\\)
  • Replacement Text: <blank>
  • Use Regular Expressions: yes
  • May 15, 2016
Thank you so much! It worked. I need to learn the RGEX code!
  • May 16, 2016
See also the help on the StringSearcher to learn more about regex.
klingdom
Forum|alt.badge.img+5
  • August 22, 2023
I have something similar. We need to remove the "POLYGON((" at the begging and the ending "))" I keep getting a red mark on the first parentheses. FME is seeing it as part of the formula. POLYGON((-75.9233547904934 40.2630624281009,-75.9235459763934 40.2625868196687
klingdom
  • August 22, 2023
geomancer
Forum|alt.badge.img+51
  • August 23, 2023
If you have parentheses as characters in your data, you may have to escape them with a preceding \ (in a StringSearcher), or enclose the search string in double quotes (in an AttributeManager and the like). You may see red parentheses in the Text Editor, but the string replacement will still work correctly.
Parentheses
Used in the AttributeCreator:
@ReplaceString(@ReplaceString(@Value(WKT),"))",""),"POLYGON((","")
Used in the StringSearcher:
POLYGON\(\((.+)\)\)
combined with the option Subextression Matches List Name to get the string defined by (.+)
For completeness: POLYGON((x y, x y, ...)) is the OGC Well Known Text format. You can convert it to geometry using the GeometryReplacer.
klingdom
  • August 23, 2023
Parentheses
POLYGON\(\((.+)\)\)
Thx for all the info!  Fortunately or unfortunately for time sack the GeometryReplacer bypassed all of this.  the fix that remove everything the POLYGON(( )) was @ReplaceString(@ReplaceString(@Value(geometry),"POLYGON((",""),"))","").  Thx again.
