how to remove empty property from a json with python
arthy
Forum|alt.badge.img+8
I have a json that I'm going to use to update features on an arcgis server.
The syntax of my json is:
_result= [{"attributes":{"OBJECTID":objectid"ATTRIBUTE1": A1 ,  "ATTRIBUTE2": A2 ,  "ATTRIBUTE3": A3,"ATTRIBUTE4": A4, ... ,"ATTRIBUTEN": AN}}]
How can I automatically remove the entries with null values?
For the example above, if A2 is NULL or '' then the json should be:
_result= [{"attributes":{"OBJECTID":objectid"ATTRIBUTE1": A1 , "ATTRIBUTE3": A3,"ATTRIBUTE4": A4, ... ,"ATTRIBUTEN": AN}}]
I tried the fillowing code inside a python caller without success.
def remove_null(feature):
    js = feature.getAttribute('_result')
    for key, value in js.items():
        if value == None or str(value)='':
            del js[key]
    feature.setAttribute('_result_bis',js)
Thanks
  • June 29, 2017
Hi @arthy, I think you have to load the source JSON document (text string) into a Python data structure before modifying the contents, then dump the result to another JSON document after modifying. You can use the Python json module. e.g.
# PythonCaller Script Example
import json
    array = json.loads(feature.getAttribute('_result'))
    for m in array:
        m['attributes'] = {k:v for k, v in m['attributes'].items() if v not in (None'')}
    feature.setAttribute('_result_bis', json.dumps(array))
[Addition] Another implementation example.
import json
    for m in array:
        for k, v in m['attributes'].items():
            if v == None or v == '':
                del m['attributes'][k]
  • June 29, 2017
import json
    for m in array:
import json
    for m in array:
BTW, why not use the JSONFormatter?
arthy
  • June 29, 2017
@takashi
I use the python caller and it worked perfectly withe the first example of your code above.
