How to read / write a .tar file?
  • Apr 12, 2018 6:33 AM UTC
  • 266 views
Hello,
Is it possible to read and unzip .tar files?
I have an interesting project that starts with a .tar file, I need to unzip that to get a .gz file, need to unzip that to get another .tar file, one final unzip to get a folder containing the data I need to edit.
So in short the structure:
.tar -> unzip -> .gz -> unzip -> .tar -> unzip = folder containing DBF and SHP files I need to edit.
Once edits have been made I need to zip everything back up in reverse order.
How would I do this?
Thanks, all the best,
Ed
Best answer by takashi
Hi @edhere, FME doesn't directly support packing/unpacking with gz and tar format. However, if you install an external command line tool which supports gz and tar, you can embed its functionality to a workspace using the SystemCaller transformer.
Probably 7-Zip is a good tool for your purpose. 7-Zip installation contains a help documentation including how to use it from command line.
  • Apr 12, 2018 7:03 AM UTC
  • Apr 12, 2018 3:09 PM UTC
I tested extracting process using 7-Zip and SystemCallers, and it worked fine. Assuming these parameters are defined.
  • $(7Z_EXE): The "7z.exe" file path
  • $(SOURCE_TAR): The source "*.tar" file path
  • $(DEST_FOLER): A directory path to which extracted folder will be saved finally.
  • Apr 13, 2018 5:30 AM UTC
Thanks @takashi , I'll give it a try.
Best,
Ed
