How to read IFC files properly in FeatureReader?
  • Sep 22, 2023 8:34 AM UTC
  • 105 views
I am trying to test a bunch of IFC files containing different sets of IFC classes like IfcBeam, IfcColumn, IfcReinforcingBar etc. When I change the filepath in a user parameter, FeatureReader changes accordingly as per the presence of IFC classes in that respective IFC file(Refer images), resulting in breaking links with the next transformers.
I also created a dummy IFC file manually adding in all the IFC classes which are there in all the IFC files I have till now. But this is not a reliable solution as future might hold some other classes as well.
Kindly try to suggest me a reliable solution I am surely missing at the moment.
fme1fme2
itsmatt
Forum|alt.badge.img+48
  • Sep 22, 2023 12:44 PM UTC
Perhaps a better option is to use the Generic (single) output port followed by a FeatureTypeFilter. This way the FeatureReader will always read all of the FeatureTypes and you can set up a FeatureTypeFilter (or AttributeFilter) to split the feautres. The FeatureTypeFilter will not change depending on the input file
