How to properly set up the FeatureWriter to dynamic and avoid exporting feature with empty or '<missing>' attributes?
  • Feb 7, 2022 6:42 AM UTC
  • 404 views
I have a workbench that generates features with about 20 attributes.
Not every run will have the same source and so not every run will fill the 20 attributes in the feature writer.
I have used the NullAttributeMapper just before the FeatureWriter to map null and empty attributes to missing, but it still outputs all the <missing> attributes. I have tried both Automatic and Dynamic, but same result.
What's the best way to only output the attributes that aren't all 'missing'?
featurewriter
Best answer by markatsafe
@ts_84​ In FME 2021.2 or FME 2022 betas we've introduced SchemaScanner. This has an option to ignore <missing> attributes when it generates the schema feature. You can then use the schema feature in your dynamic writer
  • Feb 8, 2022 6:53 PM UTC
  • Feb 9, 2022 1:01 AM UTC
Thank you, that sounds perfect. How do you set up the <missing> parameter in SchemaScanner?
I can't find the Schema Feature in the dynamic writer, is it through Schema definition name?
missing f-writer
@ts_84​ Have a look at the SchemaScanner demos we recorded here
  • Feb 22, 2022 7:06 AM UTC
The SchemaScanner is perfect thank you. It works really well with Shapefiles.
I tried with Geopackage and it's not handling it quite well for some reason. Without the SchemaScanner it's ok.
Problem with fme_feature_type. I think it's missing proper id or something like that to build the Geopackage.
