How to process items grouped by a field, for multiple transformers.
  • April 8, 2024
  • 52 views
ecx
Forum|alt.badge.img+5
I have 100 items of data, which are grouped together in various sub groups using a field 'groupNo',
I want to process each set of groupNos individually, I need to select a group, and do the following processes for each individual group: Take one item with status 'original' which has data and duplicate that data to the 'new' items in that group. How would I do this using the groupNo identifier?
An example input output data set:
Input:
OID, Status, Data, Group
1, Original, XYZ, 1
2, New, <null>, 1
3, Original, ABC, 2
4, New, <null>, 2
5, New, <null>, 2
Output:
1, Original, XYZ, 1
2, New, XYZ, 1
3, Original, ABC, 2
4, New, ABC, 2
5, New, ABC, 2
davidlee
Forum|alt.badge.img+7
  • April 8, 2024
There are many ways to process it. You can use FeatureMerge to merge attributes. Firstly, you have to filter Null value and has a value of "Data" field, then you can use set of Null data as Requestor with key "Group", and set of has a value data for Suplier with key "Group". You will have a result with features with attributes are merged, then use another transformers to get attributes you need such as AttributeRenamer, CreatorAttribute, AttributeValueMapper.....
