How to populate Schema Mapper lookup table attributes Type and Mapping Type?
  • Mar 21, 2022 7:32 PM UTC
  • 112 views
I'd like to find some documentation or information regarding the lookup table attributes 'Type' and 'Mapping type' associated with the Schema Mapper. I have done a lot of digging around the FME knowledge base and cannot seem to figure how to format the values associated with the attributes.
This article has many different use cases associated with the Schema Mapper. I downloaded the associated FME Workspace and CSVs. The CSVs have different values assocaited in the 'Type' and 'Mapping type' fields.: https://community.safe.com/s/article/schemamapper-use-case-example?r=1807&ui-knowledge-components-aura-actions.KnowledgeArticleVersionCreateDraftFromOnlineAction.createDraftFromOnlineArticle=1
@cwchumley​ I think if you work through the tutorial first the different uses of Schema Mapper will become clearer. The 'types' and 'mapping types' that your referring to in the article you referenced are just conceptual ideas and not SchemaMapper functionality
