How to pivot or change the layout of a data table?
  • Oct 20, 2021 8:54 PM UTC
  • 129 views
trevorb
Forum|alt.badge.img+3
I am trying to go from this:
initial_weather_table
to this:
weather_tableWhere "Current Weather" is the first "validTime" record and "Next 24 hrs" is the second "validTime" record.
I messed around with the concept in excel and came up with the following which might work but can't seem to replicate it in FME:
pivot_excel
I've played with the AttributePivoter, StatisticsCalculator, AttributeExploder, and others and just can't seem to alter the table to something similar to what is shown above. The idea would be to go from reading in arcgis server service features and write out to an html table (or maybe something else) which would look like (or similar to) the above table.
Any ideas are greatly appreciated!
Best answer by itsmatt
So the AttributeExploder is definitely needed here. Here's an example workflow
imageThe aggregator can then be used to get the data inline
itsmatt
Forum|alt.badge.img+48
  • Oct 21, 2021 9:03 AM UTC
itsmatt
  • Oct 21, 2021 9:04 AM UTC
Here's what the output looks like
trevorb
  • Oct 21, 2021 8:11 PM UTC
Your workflow worked for my needs. Thanks so much!
