How to perform a 'for each' loop in FME?
  • Dec 24, 2020 1:57 PM UTC
  • 2911 views
Dear all,
I use FME to perform a complex comparison analysis between two large datasets. I am looking for a way to analyze various subpopulations in succession, in order to reduce memory usage and increase performance. I have defined the desired subpopulations in a Reader file, so they can feed the SQLExecutor transformers to obtain the subsets. After performing the analysis on the first subset (i.e. 'Apple') and writing the results to a report file, the next subset (i.e. 'Banana') should be analyzed and so on.
fme
How can I implement such a 'for each loop' within FME?
Thanks in advance.
Remy
Best answer by ebygomm
I'd personally use a parent workspace with a workspace runner to run the workspace for each line in your file, you should be able to use send Source_1 and Source_2 as parameters in the child workspace
hkingsbury
Forum|alt.badge.img+73
  • Dec 24, 2020 8:31 PM UTC
Forum|alt.badge.img+54
  • Dec 29, 2020 9:32 AM UTC
Workspace runner or a batch file will be your best bet.
If you are running something in a specific order and one at a time the runner works well.
If you running a comparison between the first two, comparing the result of that run to the next, etc. A batch file with a series of calls/start would let you spawn all the instances at once as independent processes. You can run up to 8 processes at a time.
  • Dec 31, 2020 10:37 AM UTC
Exactly what I was looking for!
Firstly, I added two Published User Parameters to the initial (child) workspace:
01
After which I changed both SQLExecutors to SQLCreators that use the published parameters as SQL Statement.02At last, I created a parent workspace that affects the published parameters.
03
Thanks a lot!
