How to pass features to GeometryValidator in loop
  • Mar 5, 2014 2:26 PM UTC
  • 5 replies
  • 46 views
I have notice that some features have to go through the GeometryValidator more than one time to be completely repaired from topological errors. I thin this happen when a feature have more than one error, but I am not sure if it is the only reason.
Is there a way to pass features in the GeometryValidator in loop until they are clean? I use to put 2 or 3 GeometryValidator in queue to do the job, but sometimes it is not enough and it is not really neat in the workspace.
Thanks a lot
-Max Demars
  • Mar 5, 2014 2:47 PM UTC
yes, this is possible using a looping custom transformer.
However, be very careful as you might encounter geometries that won't repair properly, leading to an infinite loop if you don't provide for some exit mechanism after a number of loops.
David
  • Mar 5, 2014 2:53 PM UTC
Thank you David! Can you suggest such mechanism to exit the loop?
  • Mar 5, 2014 3:07 PM UTC
one solution could be to use a Counter with the Name set to the primary key attribute (I used the OBJECTID in the example below), so that you get a loop count for each attribute:
You can then test this loop counter before you decide to loop it once again. (A nice addition could be to use a published parameter for the loop count limit)
David
  • Mar 5, 2014 3:14 PM UTC
Thank you for your help! This is perfect!
fmelizard
Forum|alt.badge.img+22
  • Mar 5, 2014 7:19 PM UTC
Very elegantly done! I actually didn't realize that several passes via the validator will have any effect! Good to know! Now just wrap it up in a costumer transformer to share with the rest.:)
